Winter boredom
The truck intakes flow better at mid-low air demand, better for torque is my understanding.
T5MalibuWagon
1,386
Fort Worthless TEXAS!
I know that out at scoggin dickeys that on a lot of the 427's that they build up, I dont think that there real ls7's, they use a truck intake.
455_82malibu
1,400
WISCONSIN
its a new take off from a 6.0 truck engine. The throttle body was a brand new AC, I could have spent a few more $$ and got a 80mm but I figure the intake wont flow more then the 75mm opening.
454RAT
2,012
Summerville, SC
if this is in the wagon. then could you PLEASE tell me what you are going to run for a fuel system? Im wanting to build a LSX Wagon. and im in the planning stages. if you have pics that would be appreciated. thanks
455_82malibu
1,400
WISCONSIN
external walbro pump, conversion AN fittings so I can use the stock lines on the intake...and a factory return line. the fuel line will be Summit twist lock..good for over 200 psi. fitting will all be 6-AN. To get it running this winter Im going to use the stock tank pickup, if everything works out Ill weld a bung on the lower rear of the tank and that will be the outlet.
Pump... http://item.express.ebay.com/_Car-Truck-Parts-Accessories__Walbro-255-Inline-fuel-pump-GSL-392-With-6-fittings_W0QQitemZ230201226484QQihZ013QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQptdiZ2865QQcmdZExpressItem
Stock Fuel rail fittings.... http://item.express.ebay.com/_Car-Truck-Parts-Accessories__93-97-LT1-LS1-Camaro-Corvette-Fuel-Rail-6-AN-Fittings_W0QQitemZ360004928718QQihZ023QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQptdiZ2865QQcmdZExpressItem
did you make your own motor mounts and does the oil pan clear without any issues
