wiring for stock radio
83bu
563
Regina, Saskatchewan
does anyone have a wiring diagram for a stock radio in an 81 malibu?
Car Radio Battery Constant 12v+ Wire: Orange (it's not uncommon to tie into the cigarette power for this)
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Brown_Gbody
3,078
Milwaukee, WI
If you need a schematic, I've got the wiring manual at home. I can add photos of the diagram later on today, if you need them.....
83bu
563
thanks for the help, i actually found a good schematic for which wires go where in the harness that plugs into the radio. i think doober actually posted it on another forum i came across.
http://www.installdr.com/Harnesses/GM-Wiring.pdf
