Wiring up multiple relays, switches!
MadMike
757
Jackson, Ohio
One other thing. What is the difference in spst, spdt, dpdt etc? Which do I need, does it matter?
drwoowoowoo
94
Ft Worth Texas
MadMike
757
Jackson, Ohio
thank you, thank you very much :)
MadMike
757
Jackson, Ohio
Now what about fuses? Each circut have to have an inline fuse from the relay to the junction block? Or instead of junction block could you just go from battery to a new accessory fuse panel and connect from the relay to the fuse port?
GreenDragginBu
6,293
N.E. Ohio
Mike if you go with a aftermarket acc. fuse panel, then you could use the fuses in them going to your pumps,fans...etc.
But just amke sure that the additional fuse block/panel you use is capable of handling current...some fans have a high initial turn on amp draw...
and here is a invaluable website to check out....
http://www.bcae1.com/
MadMike
757
Jackson, Ohio
Thanks, I really appreciate all the help and guidance.
MadMike
757
Jackson, Ohio
What are the power relay module's? Looks like it has an input then so many fused circuits and then outputs.
GreenDragginBu
6,293
N.E. Ohio
Not real sure ive seen something like that used in a car...But i Have seen these used....
http://www.racewiring.com
MadMike
757
Jackson, Ohio
Yeah thats where I saw them at. Expensive too. I went to the Painless sight and it has some info also. I messaged tech support to get there recommendation. I will probably order the 3pak relay w/ harness, some LED's and toggles probably. Ever deal with them?
GreenDragginBu
6,293
N.E. Ohio
racewiring ??? Not me personally..
If your speaking of Painless stuff...yeah
