What kinda MPGs witha stock 3.8 2v? UPDATED
Info and tech for V6 engines
Moderator: Moderators
Post Reply
shotgun
Post by shotgun » Sat Jan 01, 2011 5:43 pm
I put a deposit on a car finally.
The plan is to drive it and see what it needs and then build from there.
What kindas MPG can I expect?
It is a 85 Bonneville 4 door.
'Bu-Camino
Re: What kinda MPGs witha stock 3.8 2v?
Post by 'Bu-Camino » Sat Jan 01, 2011 6:00 pm
Well.....just for reference I had an 81 g-body in college with that engine. The rear gears were something in the 2.90 range and I kept it under 70. MPG was about 18 or so if I remeber correctly. Lots of variables though in these age of cars.
1978 Malibu
406 w/AFR 195's, 9.9:1, 6" rods, Lunati 60103. TH400, 10 TCI converter. 8.5" w/Eaton, moser axles, 3.73's.
7.55 @ 91 mph. 1.68 60'
shotgun
Post by shotgun » Sun Jan 30, 2011 7:27 pm
Ran the codes , this has a 2.41 rear . The trans upshifts way early so she is a dog in drive.
Tried just leaving it second and feels pretty good, engine is in it's power band.
Does not feel likes it's revving cruising at 45.
Post by t5montecarlo » Sun Jan 30, 2011 7:58 pm
2:41 would have been my first guess.
I would expect the rated mpg was about 20/24. Have you been able to find any documentation citing original mpg ratings for the car?
bukweet
Post by bukweet » Sun Mar 06, 2011 9:06 am
My longroof had 2:73's from the factory.
Was a pretty good gear for the 3.8 buick V6.
I put 3:42's in it and while it woke it up, it was way to tight at highway speeds with a turbo 350 transmission. Overdrive or a lock up convertor would been a great thing to have.
Put some 255-60-15's on it and took a few rpm out of it.
If you do nothing but city driving, 3:42's would be cool.
8)
bukweet
" Backyard Bonneville Longroof "
SOLD
Livin' for Him 'cause He died for me.
Artificial intelligence is no match for natural stupidity.
Post by t5montecarlo » Sun Mar 06, 2011 9:20 am
Are you considering changing the gears and using the wagon T5?
shotgun
Post by shotgun » Fri Apr 29, 2011 11:07 am
Finally got my 85 Bonnie inspected and on the road.
Ran a tank of gas threw before started keeping track of MPG , had to fix the trans etc.
Anyway , getting a hair under 17 mpg.
That is suburban, drive to work, driving, rarely sees over 50 mph. Did get the a/c working and used that 1/2 the time.
What are you other 3.8 V6 guys getting?
Re: What kinda MPGs witha stock 3.8 2v? UPDATED
Post by t5montecarlo » Fri Apr 29, 2011 7:20 pm
I used to be able to squeeze about 18 in the wagon on 35-45-mph roads going to work and back. A lot of time was spent in 5th gear.
dragonmaster093
Post by dragonmaster093 » Sat May 19, 2012 10:53 pm
i get between 16-18 depending how i drive and what roads i take (ie. flatter ones or hills/mountain roads)
Darwinskeeper
Post by Darwinskeeper » Mon May 21, 2012 2:43 pm
The last time I checked, Darwin's anything but stock 4.3 was getting 16-18mpg in mixed driving even with a leaky 4160 and 2.41 gears.
Her best mpg was recorded during my only major road trip back when she had 2.73 gears, a Comp 252H camshaft and a freshly rejetted Holley. I saw mileage in the low 20s running 65-70mph with the windows up and the AC running. My best mileage was 24mpg at 65mph
"All middle aged men are pigs," Porco Rosso
Darwin, a 1979 Malibu Wagon with a 3 speed Manual box and 2.41 gears in back
Engine is a '85 4.3 V6 topped by an Edelbrock Performer and a 465cfm Holley 4160. The heads have a 3 angle valve job and the cam is a Crower Level 1 240HDP grind with Comp Magnum 1.52/1.60 rocker arms. Full headers with 1 1/2 primaries dump into duals with 2 1/2 tubes and turbomufflers.
toyodajeff
Post by toyodajeff » Sat May 26, 2012 9:00 am
when my el camino still had the chevy 3.8 I got 21mpg's on on the highway going 55. It had a rebuilt 229 with all the emissions equipment removed, a th350 and I'm pretty sure 2.73 gears
Post Reply
