1978 cutlass original 5 speed
Questions, answers, tips and tech on drivetrain issues.
Moderator: Moderators
Post Reply
klopper92
Post by klopper92 » Mon Jun 06, 2011 7:39 pm
ok so my dad has a 78 cutlass salon with the original 5 speed. it is a borg warner t50 unit which is locked in third gear. i am wondering how rare this car is and if there is anyone out there that provides parts for that particular trans. i was going to use the trans in another project car but need a few parts for it. but from my searching on the internet have realized that there are very few manual trans g bodys out there. does anyone have any info bout these cars or if its worth restoring or should we just part it out.
Killerdave8813
Re: 1978 cutlass original 5 speed
Post by Killerdave8813 » Mon Jun 06, 2011 7:52 pm
I don't know what a Salon is,rear wheel drive or front? If it's a cool car (rear drive) it's worth restoring,repairing or playing with,very few manual trans G-bodies? I have two,Malibus actualy,one factory and one conversion and there are bunches more out there,T50 trans is a paperweight and that is being very kind,you can probably find parts and repair it but any kind of performance driving and you'll just break it again,there are plenty of alternatives,T5,Tremec,T56,Muncies & T10 four speeds,It just depends on what you want to do! KillerDave
81 Malibu Ex V-6 3spd,267 V-8 305 HO cam,600 Holley,HEI,Dougs Headers,3" Pypes exhaust w/ X-pipe,168 toothflywheel,11"clutch,
Muncie M-20 big spline trans,Hurst Comp Plus shifter,3 1/2" steel driveshaft,Moser 9" 3:50,Edelbrock adj uppers,Southside lowers,
Modified Moog springs,Cop Car gearbox,antisway bars & frame braces,
urethene bushings,Goodmark hood,More coming soon!
Post by t5montecarlo » Mon Jun 06, 2011 8:04 pm
It only came behind the 260 Olds engine in the Cutlass, so it should last when repaired. I would suggest keeping the car original since it is not a common package. It is the same transmission used in the Cosworth Vega as well as Monzas and related H bodies, though the internal gear ratios may be different.
klopper92
Post by klopper92 » Tue Jun 07, 2011 7:48 pm
heres a few shots of it i took with my cell a while back. u are correct that it has the 260 engine. it also had a peg leg 2.56 10 bolt so im gonna assume that first gear in the trans is very low to get the car moving.
klopper92
Post by klopper92 » Tue Jun 07, 2011 8:07 pm
cutlass salon
Killerdave8813
Post by Killerdave8813 » Tue Jun 07, 2011 8:30 pm
Cool,That's one of those Buttless Cutlasses they were talking about on another thread in here!! It ought to be worth messin with if you like it!!
Post by t5montecarlo » Wed Jun 08, 2011 7:31 pm
If you don't want to keep it original, a 455 Olds might be a neat replacement engine.
Post Reply
