Timing Mech vs Vac advance Good Read
Questions, answers, tips and tech on drivetrain issues.
Moderator: Moderators
pgamedog
Re: Timing Mech vs Vac advance Good Read
Post by pgamedog » Fri Jan 23, 2009 8:28 pm
Will the Echlin #VC-1810 work on Hei distributors ? If not does anyone know a similar can that will.
pgamedog
Post by pgamedog » Mon Jan 26, 2009 12:19 pm
Found this on another site.
HEI Distributors:
P/N ID# Application Starts @ “Hg Max Adv
(Distr. Degrees @ “Hg.)
VC1838 AR12 1975 350 Buick 7-9 7 @ 10-12
VC1843 AR15 1977 305 All Exc. Hi Alt, Exc, Calif. 3-5 7.5 @ 9-11
1974 400 All w/2-bbl
1977 305 El Camino
1976 262 Monza Exc. Calif
1976 350 Vette Hi Perf, Incl. Calif
1975 350 Z-28
1977 305 Buick Skylark
VC1853 AR23 1976 350 All Calif. 5-7 7.5 @ 11-12.5
1976 350 Vette Calif., Exc. Hi Perf
1976 400 All, Exc. Calif
1975 350 4-bbl
1974 350 All w/1112528 Distr.
1978 350/400 Heavy Duty Truck, Exc. Calif, Exc. Hi Alt.
VC1862 AR31 2-4 8 @ 6-8
VC1703 N/A 1978-79 Vette Special Hi Perf N/A N/A
1979 305 El Camino Calif.
1978-79 350 Blazer & Suburban
1979 Buick 305/350
VC1825 AR1 1976 454 Caprice, Impala 3-5 9 @ 6-8
1975 454 Caprice, Chevelle, Monte, Suburban
VC1826 AR2 5-7 12 @ 10-13
VC1827 AR3 5-7 9 @ 9-11
VC1828 AR4 1975-76 350 Buick & Olds 6-9 10 @ 12-14
1976 350 Pontiac
VC1831 AR7 6-8 12 @ 14-16
VC1832 AR8 1975-76 455 Buick Electra 4-6 12 @ 12-14
VC1833 AS1 1975-76 500 Cadillac Exc. Calif. 4-6 14 @ 15-16
VC1834 AR9 4-6 13 @ 13-16
VC1835 AS2 1975-76 350 Olds 5.5-7.5 12 @ 15-17
VC1836 AR10 1977 305 All Hi Alt, Exc. Calif. 3-5 9 @ 11-13
1977 350 All exc. Calif.
1977 350 Vette Exc. Calif, Exc. Hi Perf
1976 305 All Exc. Calif
1976 350 All Exc. Vette, Exc. Calif
1976 350 Vette Exc. Calif., Exc. Hi Perf
1975 262, 350 All w/2-bbl carb
1975 350 All 4-bbl w/ 1112880 & 1112888 Distr.
1977 305 Chev Truck Light Duty
1975-76 350 El Camino 2-bbl
VC1837 AR11 1976 305 Blazer, Exc. Calif 6-8 12.5 @ 10.5-13.5
1976 350/400/455 Pontiac 4-bbl
VC1839 AR13 4-6 12 @ 11-13
VC1840 AR14 1975-76 350/400/455 Pontiac Firebird 6-8 10 @ 9-12
VC1841 AS3 1975-76 500 Cadillac Calif. 5-7 10 @ 13-14
VC1842 AS4 1976 350 Olds Cutlass 5-7 12 @ 13-15
VC1844 AR16 3-5 12 @ 13.5-15.5
VC1845 AS5 1978-79 425 Cadillac w/F.I. 4-6 14 @ 14-16
1977 425 Cadillac
VC1846 AR17 1977 301 Buick Skylark 3-6 13 @ 10-13
1977 301 Pontiac
VC1847 AS6 1978 403 Motor Home 4-6 12 @ 12-14
1977-79 350/403 Buick LeSabre Hi Alt, Riviera, Olds
1977-79 350/403 Pontiac Hi Alt
VC1848 AR18 4-6 12 @ 9-12
VC1849 AR19 4-6 12 @ 7-10
VC1850 AR20 1977 350/400 Pontiac 4-6 10 @ 8-11
VC1851 AR21 1977-79 350 Buick LeSabre, Century 5-7 12 @ 11-13
1978-79 350 Pontiac
VC1852 AR22 77-78 305/350/400 Chev Truck, Heavy Duty 7-9 5 @ 12-14
1975-76 350/400 Chev Truck Heavy Duty
VC1854 AR24 3-5 13 @ 10-13
VC1855 AS7 1977-79 260 Olds Cutlass 3-5 15 @ 10-12
VC1856 AR25 3-6 15 @ 10-14
VC1857 AR26 3-6 12 @ 13-16
VC1858 AR27 1978-79 305 All 3-6 9 @ 11-13
1978 350 Camaro
1978 305 Chev Truck, M/T, Light Duty
1978 350 Chev Truck Hi Alt
1978 305/350 Buick & Olds
1978-79 305 Pontiac
VC1859 AR28 1979 350 Vette Exc Hi Perf 3-6 10 @ 9-12
1978-79 305 w/1103282 Distr., Incl. El Camino A/T
1979 350 Camaro, Impala, Nova, Malibu, Monte
1979 350 Suburban
1979 350 Buick Century
1978-79 305 Pontiac Hi Alt.
VC1860 AR29 3-6 12 @ 10-13
VC1861 AR30 1978-79 301Buick 3-5 13 @ 11-13
1979 301 Olds
1978-79 301 Pontiac
VC1863 AR32 2-4 10 @ 11-13
VC1864 AR33 1978 305 Chev Truck, A/T, Light Duty 4.5-6.5 13 @ 11-13
VC1865 AR34 1973-74 350 Vette Special Hi Perf 3-5 15 @ 8.5-11.5
VC1866 AS8 1978-79 425 Cadillac w/carb 3-5 14 @ 13-15
VC1867 AS9 2-4 10 @ 8-10
VC1868 AR35 1979 305 Chev Truck & El Camino 2-4 10 @ 6-9
1979 305 Buick & Olds
1979 305 Pontiac A/T
VC1869 AS10 2-4 12 @ 8-11
__________________
bowtie81
Post by bowtie81 » Mon Jan 26, 2009 3:31 pm
That is very good info! thanks
350 .060 over
dart pro 1's
B&M 162 blower
750 demon
turbo 350 3500 stall
12 bolt 456 gears
MalibuMan1979
Post by MalibuMan1979 » Mon Jan 26, 2009 4:34 pm
this explains a lot to me. i have a holley 750 w/ vac. secondaries. i put a proform carb body on it. the proform carb body has no provisions for a ported vacuum source. so i plugged the vac can, and set my total timing for 34 degrees. i read later that a vehicle with vacuum advance will idle cooler than without. since i run the street the most i bought vacuum tees to install my vacuum can back on manifold vacuum. while i was at the strip i ran my best with out vacuum can attached. i though, what the heck, i will tee in and run again just to see what happens. i installed the tee and ran again. no change at all. i even came back to the pits and watched my temp guage to see if it idled cooler. no effect there either. i check my timing at idle and pulled and plugged the vacuum line going to the can and the timing stayed the same. i didn't even think about idle vacuum. my car idles with about 8"hg. if my vac. advance can only pulls at 8 or more, (it's adjustable petronix kit on a hei), than my engine had no vacuum advance. this is why i love to read stuff like this. gives me some knowledge. thanks for the article.
MalibuMan1979
Post by MalibuMan1979 » Sun Mar 21, 2010 11:44 am
new update. my vacuum source is maniflold not ported. i set my timing at 34 degrees total @300rpm, (350 small block). my initial was at 14 with no advance. my mechanical was all over the place as rpm increased. by changing my advance springs produced no visible change. i pulled the hei and checked the bushings and such. rebuilt the distributor with new bushings that my b-i-l had in a kit along with another hei for parts. cleaned up the mechanical advance issue. noticed when i was cruising at 55 mph, the engine seemed to lunge quite a lot. attached a hand vacuum pump to the vacuum mod and had no movement in the arm. scrapped that can and went to the autoparts store and bought a accell adjustable vacuum advance can. when installed on the stock settings my timing advanced to 18 degree at idle, my vacuum went from 9 in to 12 in and still kept my 34 degree total timing. best thing is my cruising speeds are smooth as silk. if you are going to street your car, keep the can.
Post Reply
