speedometer gear drive
Moderator: Moderators
how many teeth on gear drive on 350 turbo do I need for 373 rear for speedo to read right or at least close
- t5montecarlo
- MalibuRacing Junkie
Re: speedometer gear drive
With a 25-inch tire, you need a 3:1 ratio between the drive/driven gear. You need to know how many teeth are on the gear inside the transmission and then multiply by 3 to get the proper driven gear (the one that is easily removed).
