Speedometer cable problem
78elk
1,294
81
Mountain Home Id
How does a person know if the cable is connected properly? I have several connections between the speedometer and transmission.
Vilanus
22
Canada
Try unpluging different parts while spinning your driveshaft. If everything spins with the drive shaft your problem at the gauge cluster. If nothing spins its your transmission speed sender. Or where ever it stops spinning will be the problem
78elk
1,294
81
Mountain Home Id
I tried running the cable with my drill in reverse, which made the cable unravel some. So I plan to get a new one. The one that's in there now has 2 or more feet sticking out under the hood. So I plan to get a shorter one.
78elk
1,294
81
Mountain Home Id
I decided to put a new cable inside the the sheath. It has one square end. Where does the square end go, in speedometer or transmission?
