Autometer Speedometer
Swap and other information about GM's LSx series engines
Moderator: Moderators
Post Reply
80bu
Post by 80bu » Fri Jan 31, 2014 6:25 pm
I am taking out the factory gauge cluster and putting in autometer tach,speedo and fuel level gauge. Do I need the sender from autometer to hook up my speedo? What wire do I use for the fuel level gauge and do I need a sender for this? Also which wire's do I use for the turn signals? I am running a ls1 with a t56 out of a 2002 Camaro. Where do I get the sppedo signal from the harness?
Thanks for the help!
1980 Malibu
Ls1 T56, Money well spent!!!
bigmandengo
Re: Autometer Speedometer
Post by bigmandengo » Fri Jan 31, 2014 11:11 pm
I assume you are using the factory 02 ecm and harness? You can access ecm pinouts to determine the wires you need for your tach and speedo on lt1swap.com. The stock ecm does have a speeo and tach output. As far as the turn signals, you will have to splice into your original cluster harness for these wires. You may check the wiring diagrams in the tech section.
80bu
Post by 80bu » Sat Feb 01, 2014 5:50 am
I am using the stock 02 ecm and harness.
1980 Malibu
Post Reply
