Which one are you using ? Steel Concepts recommends i get one for the manual brake kit . Like the wildwood #260-1876 , is that what i'll need ?
Supe said:Wilwood, speedway, etc. Just check your fittings and make sure they don't bottom out. Wiseman had a problem with that with his wilwood unit.
tnt2671 said:what are you using for fittings? regular line w/ double flare?
