wiseman79 said:Then why do you need a residual valve when going to a disc/disc MC on a drum brake car?
You don't, unless you remove the proper combination valve, like when you use a full Wilwood or other after market system. Sometimes residual valves are used when the master is level with or lower than the wheel cyliders.
The following info was taken from Power Master Brakes' site:
"There are two different uses for residual valves. The 10 lb valve is used to hold a residual pressure to the drum brakes to keep the shoes out close to the drums giving a higher firmer pedal. The 2 lb valve is used in the disc when the master cylinder is lower than the calipers to prevent back siphoning of the fluid from the master."
