383 pic of progress
JOHNWOJO
402
New Jersey
Cant seem to find it on the site but here is the grind #i think lol 47RRA272H280G106 if i remember (dont have the cam card in front of me it is around 650 lift and around 300 advertised duration but duration at 050 is around the 272 280 mark. I will try and get the actual #s for you.
JOHNWOJO
402
New Jersey
Ok specs off of cam card. Semi custom grind had to call them and tell them what i wanted.
pt# 50199ALUN
grind# 47RRA272H280G106
lift 669 intake 648 exhaust
adv. duration 305 intake 313 exhaust
duration at 50 thousands 272 intake 280 exhaust
mean78malibu
998
Thanks dude. Will you run at Cecil @ all in '11? That should have some motivation @ 14:1
Do you think the block needs filled for that power level? I have a set of 6" scats and lightweight pistons (block is already studded w/ splayed 4 bolt caps), would just need to get the right crank.
You gonna ditch the 4.88's with this one?
JOHNWOJO
402
New Jersey
Never been there i run at atco. Friend of mine had the block and it was filled already. Almost same combo went 10.08 in his 3000 lb nova. Im looking for 10.50 or better. The 4.88s are going to stay my plans are shifting the powerglide around 7000 and crossing the stripe at 7500. fastheavychevy not sure what pics you see but i have only posted one. Thanx agian
JOHNWOJO
402
New Jersey
couple more pics o motor and ill see if i have one of the car
JOHNWOJO
402
New Jersey
last 2 of motor
