Anyone have a wheel with this much bs? I need to know if a Weld or the like will work with a Wilwood brake setup or if the caliper will hit. I can't narrow the rear end without changing the lower mounting brakets so I was going to go with more bs.
Im running 10 inch Alumastars with 6 inc bs which is actually 6 1/4 from the lip.I also have a Wilwood rear disk setup and it clears fine.The shock mounts are tight,but I just had to use the stock style bottom shock bolt instead of the ones taht came with my Comp engineering 3 ways.
Malijuice, are your rears all the way under the car? How much notching, minitubbed? I am trying to fit that very wheel under mine presently. Oh yes, what tire and size?
