6.0 motor and transmission are in!!! - NOW A STICKY
Phantom
1,709
DeSoto Wi
You have any guesses ion what kind of power it will make at the crank?
78Bu88SS
1,241
Cape Cod, MA
Exactly the setup I want to do, I'm glad someone found a set of mounts a pan that fit nice. Last hurdle is the headers, hopefully the ones you ordered fit....keep us updated. Good job!
455_82malibu
1,400
WISCONSIN
my brother has the same engine in his s10, it loves 7000 rpm, with a small shot of Nos it runs low 11's. these engines purr.
Roller406Bu
396
Elizabethtown Ky
is the part number for the adapter plates 4592?
yes sir, you'll use your stock clamshell syle ear mounts though, not the ones they send.........kinda sucks just need the plates i have a graph so you can make em if you want it...
Roller406Bu
396
Elizabethtown Ky
Roller406Bu
396
Elizabethtown Ky
the cam i got has given stock motored camaro's anywhere from 65-75 horse at the flywheel, should have close to 450 my guess I'll let the et's do the talkin though....
MalibuRacing
3,465
www.maliburacing.com
I thought about the same setup (6.0 truck motor), but get the Patriot LS6 (small chamber) Stage 2 or Stage 3 heads and cam setup. They say 500+ HP with that setup on the 5.7 engine. Here's the links:
Heads: http://www.patriot-performance.com/waterNew/default.asp?T=505234&DID=1225
Cam: http://www.patriot-performance.com/waterNew/default.asp?T=507473&DID=1225
Do you know what your chamber size is with the heads shaved .020"? Keep us updated!!!
