700r4 tv cable bracket help
uneek1976
56
For you guys that's using a 700r4 behind your ls motor what kind of tv cable bracket are you using? also I read that if you have the constent pressure valvebody(which keeps the pressure @ the same psi) in the 700r4 then the bracket would not have to use a tv bracket? I'm not sure how true this is.
Fatkaz10
12
Mapleton, IL
I don't know about the valve body, but call Bowtie Overdrives. They know their stuff, the will probably recommend the TV made easy kit.
Here's one:
http://www.holley.com/20-113.asp
Constant pressure just takes care of the pressure issues from TV cable maladjustment far as I understand, you still need the TV cable to take care of shift points. I have a different cable bracket on my truck. Since I swapped to Vortec heads I needed a throttle cable bracket too. I'll probably get one for the Malibu too since it has Vortecs, right now it has one of those cheap universal chrome Spectre brackets from Autozone.
http://www.summitracing.com/parts/EDL-8032/
