87 suburban 454
Twister79
163
Orangeburg, SC
i have a 87 suburban with an stock 454ci engine i think it have open chamber heads on it now but i have a set of 3931063 heads that are closed chamber what will be my compression ratio and will it speed up alot or just a little that i will not notice (this is an comlpete stock engine)
Twister79
163
Orangeburg, SC
hello hello hello hello i know this is not suburban racing but a little advice will be nice :shock: :-k
toxicbu
616
romeoville il
i think you will be better off with
the open chamber heads ther more eficent
the closed chambers shroud the
exhoust valve
thats why the 427 s block ridge was taperd
exhoust valve
X2 & more importantly, you can't run open chamber pistons with closed chamber heads...
JamesC459
182
fitzwilliam NH
You can put those 063 heads on a flat top 454. Those heads are NOT the bathtub style closed chamber@ 85-90cc.They are semi-open and the chamber wall is laid back on the spark plug side and they measure 100-105cc. Your overall compression ratio will jump from 7.8 to 1 to a staggering 8.6 or so.But,they do have the same intake runners/volume as the 781/049 oval port stuff that works good.
Twister79
163
Orangeburg, SC
so this is an good idea =D>
and this is like an 56hp gain right ? :D
Twister79
163
Orangeburg, SC
do you guys think this is an good combo for my stock 1987 454 750 dp card, performer rpm air gap intake, roller rocker, lunati voodoo cam 268/276 .542/.554 1800-6200, worked 063 heads, 2800-3200 converter
I didn't see he had 063 castings in his post. :oops: 063, 802, 215, 290 are all of the "semi open" design.
