mean78malibu said:To start with the basics....Are you following the ZEX tuning baselines for the specific plate, and was the system new when you put it on?
That type of plate circulates nitrous and fuel around the entire body of the plate, and it has more orifices than a spray bar plate. Therefore, you need bigger jets than a spray bar system would require to keep the pressure right so delivery is consistent. Also, is it using their solenoids, and are they rated above 150hp?
I would think 110 octane is plenty for the main fuel system and nitrous system. A good way to see what is going on would be to read the plugs as mentioned. Very possible it is leaning out.
Yes, i bought the kit new, and the solenoids are rated up to 300. it came with the jets for a 50,100... so on up to 300. im putting the jets and setting the retard exactly as they say.
Fuel is set at 6 psi flowing like they want, everything... bottle is always around 950-1000 psi.
