AFTERMARKET WIRING HARNESS
LIVE4RDO
678
Staten Island, NY
Hey crowd. Thanks to Sandy, I might need to re-wire the Bu. Is there an aftermarket harness made for our cars or could be modified for our cars?
Don't feel like using another factory one, no matter how nice, they are 30 + years old.
Thank you.
78_Elky
1,680
Oregon
smlblk78.onlineshowoff.com
I used a fuse block that came with 20 circuits and a ton of wiring. I got it off of ebay about 5 years ago and it worked great. All the wires have the circuit label printed onto them every foot or so. I want to say it was called EZ2Wire or something, whatever it was the cost was great. I think I paid less than 175 for it. I also redid all the sockets and most of the factory terminals while I was at it. I had a factory fuse block start to short and do weird stuff and I never wanted to buy another with them being so old. I mounted it in the factory position, but it is a lot smaller. It also has a larger wire coming in from the battery and it helps to not overload the circuitry. Overall it was a nice upgrade.
Jess
LIVE4RDO
678
Staten Island, NY
Any more suggestions?
One from Painless will probably work. I don't know if the bulkhead from the same era Camaro/Firebird is the same but they make a direct-fit harness for them. You may be able to have them make one with the bulkhead, leave the wiring un-terminated, and include the proper connectors so you can put it all together at home.
D Retrofitting aftermarket wiring harness (and other ideas)... Electrical/Wiring Technical 10
abigda aftermarket wiring harness, or not??? Electrical/Wiring Technical 6
7 What's the best aftermarket cruise control Drivetrain Technical 4
7 Aftermarket fender problem? Autobody/Paint Technical 6
7 Best aftermarket brands Autobody/Paint Technical 6
D Aftermarket a-arm wheel clearance Suspension Technical 2
M aftermarket rear coil springs Suspension Technical 5
M aftermarket cd player installation? Electrical/Wiring Technical 2
7 aftermarket radio install Interior Tech 4
7 Aftermarket radio install Interior Tech 17
scuba_steve's_bu aftermarket seats Interior Tech 0
MalibuRacing Aftermarket console with aftermarket shifter? Interior Tech 23
M Malibu aftermarket fenders? Autobody/Paint Technical 5
80superbu Help picking aftermarket 9" 3rd member Drivetrain Technical 6
T Constant Power Source for Aftermarket Head Unit Electrical/Wiring Technical 4
LS6 Tommy Aftermarket center link? Suspension Technical 4
nawlins-tim Aftermarket Wheel Studs Wheels/Tires/Brakes Technical 7
M Aftermarket header panels? Autobody/Paint Technical 2
D Aftermarket EFI... troubleshooting, diagnostics, and service EFI Tech 13
S Those running aftermarket gauges with their swap.. LSx Tech 5
S F41 and aftermarket bracing diagrams (pics added) Suspension Technical 42
79fourdoor Aftermarket harnesses? LSx Tech 3
A Aftermarket Brake Pads? Ceramic? Carbon Fiber? Wheels/Tires/Brakes Technical 4
DOUG213XRJ 100 + amp alternator/ Factory wiring Electrical/Wiring Technical 0
M Windshield wiper wiring Electrical/Wiring Technical 1
8 Distributor wiring help Electrical/Wiring Technical 2
Macrisel Round gauge swap wiring question Electrical/Wiring Technical 1
W Wiring Harness Issue Electrical/Wiring Technical 4
82wagon Wiring an alternator Electrical/Wiring Technical 6
J Wiring Electrical/Wiring Technical 1
B LS swap wiring harness LSx Tech 11
B NEW WIRING KIT Electrical/Wiring Technical 11
bigbadbu Wiring connectors Electrical/Wiring Technical 1
L Wiring connector on fire Electrical/Wiring Technical 0
D Blower fan stopped working- need wiring help Electrical/Wiring Technical 5
O Under hood wiring harness?? Electrical/Wiring Technical 0
jaywill wiring up alternator ??? LSx Tech 19
83bu msd wiring help! Electrical/Wiring Technical 4
W new connection for wiring ford solenoid to a chevy... Electrical/Wiring Technical 2
B back up lamps and wiring Electrical/Wiring Technical 2
thumper ford soleniod wiring for perm. magnet starter Electrical/Wiring Technical 2
P malibu wiring harness Electrical/Wiring Technical 2
B alternator conversion wiring harness Electrical/Wiring Technical 0
80Grand_LeMans Help with Pontiac Tach wiring... Electrical/Wiring Technical 3
8 wiper motor wiring Electrical/Wiring Technical 1
U Worst Wiring Mess Ever Electrical/Wiring Technical 20
U Fuse Block Wiring Electrical/Wiring Technical 7
JBreu Lincoln Mark VIII 2 speed wiring help Electrical/Wiring Technical 6
406malibu78 Alternator wiring mess puzzle of the day Electrical/Wiring Technical 10
83bu taurus fan wiring Electrical/Wiring Technical 2
Similar threads
