Anyone running an L92 witn T56
samckitt
50
Carrollton, VA
Debating going that route & wondering what PCM you are running & if you are controlling the reverse lockout solenoid from the PCM & running the VVT.
Thanks
Bubuseventy8
767
Springfield, TN
facebook.com
you should be able to run the same PCM as any of the LS equipped t56 cars.
From everything I've been reading to do this the wiring harness is different as well as the PCM. I think I am going to just use a 2010 Camaro harness and PCM if I don't go for a standalone wiring harness. I am converting my L92 to hybrid LS3. Swapping all the pulleys to the LS3 setup so I can just used a Camaro VIN# when ordering parts. Hope this helps. I'm sure someone else will chime in eventually
388bu
3,228
Huntley, il
www.shiftn6.com
I cant comment on the VVT stuff, but the T56 side of it is simple. Any ECM should do. You'll just "turn off" the auto trans stuff. Dont worry about the reverse lockout, just muscle it into reverse, thats what I do. You get used to it quick.
79loserbluebu
302
Illinois-60491
I don't beleive you can use VVT with a manual transmission. However it's very simple to switch to a standard cam setup. Lifters, valley cover, cam and timing set
79loserbluebu
302
Illinois-60491
Ahh yes DoD and VVT I was thinking DoD when I said my last comment.
