I have a 350th in my Bu with a 3000 stall behind my 383. I only have about 3 miles on the car since I installed the motor and transmission, The transmission was rebuilt. My question is, after driving the car and getting it up to temp, I checked for leaks. None were found. I parked the car and about 30 minutes later I went out and made sure nothing was dripping. It was fine no leaks. I went out the next day to work on the car and there was a puddle of trans fluid under the car as big as a garbage can lid. I put the car on ramps and checked the pan the lines and dipstick tube because thats where the leak looked to have originated. Lines were tight, I snuged the pan bolts just a little and fired the car up. I went a couple miles brought it up to temp and then pulled it back into the garage and checked again. No leaks! I went back out to check about an hour later, still no leaks. This morning before work, another puddle as big as a garbage can lid!!
Whats up????
Whats up????
