Brake bleeding question
junk racing
So I got my strange 9" installed with new brake lines and my new disk/disk combination valve should be here today so my question is all the fluid drained out am I gonna have to bench bleed the master cylinder? Any way around taking it back off? Thanks for your help
Ed Cannon
1,682
Johnson City Tn
You won't have to remove it. You can bleed it on the car. Crack the lines, slowly push the peddle down and hold it, then tighten the lines, repet a couple more times. Put something under the master to catch the fluid. A helper would be nice but you can do it on your own if you have to.
