Breaking in new engine
Robert1320
T56elcamino said:
I don't understand what you are asking. I lubed the cylinder walls with some 10-30 penzoil and installed the piston. I didn't put any additive or anything...
I asked becasue the best thing for ring break in is ATF.
Motor oil is made to float metal over metal. The AFT will
allow the rings to cut and seat. The first few minutes (seconds)
is key to proper ring seal. Although you may have heads
that are in question too. A compression and leak down test
would tell you alot about what is going on inside the motor.
T56elcamino
55
Opelousas, LA
hey thanks, so, if I do a leak down test and it loses pressure then I know it's either rings or valves, but if it doesn't it could be the studs in the heads?
