Burnout with a 400
footbrake
830
Buffalo, NY
I usually do a 1-2 gear burnout, but was told that's no good for a turbo 400 and I should do a 1-2-3 gear burnout. What's the story here? Was told that 2nd gear is a weak link coming out of the burnout box. Thanks
chevy406
84
ft pierce,fl
i read in super chevy/chevy performance that you should do a 1st 2nd burn out, and you should not be hard on it in first, to just get the rpm's up in 1st to shift to 2nd to do the burnout in 2nd gear.
racecar77
2,438
Crete,IL
I do mine starting in 2nd and shifting into 3rd as per the trans builder and never had a problem. Lee
FOFITTYFO
559
Van, Tx.
x2
Hippi
158
ILL
always 2-3 in most three speed autos,if you have to use first take it easy on the rpm's until you get it into second then let it fly.
http://www.yellowbullet.com/forum/showthread.php?t=120213&highlight=th400+burnout
for all others please read the above link I have lost a trans (and some of the motor with it)doing the 1-2 burnout
TNTS79
1,252
Illiniois
What about a 700R4?? I usually start in first then let it shift to second about 3000-3500 easy on rpms... Then hold second at about 4000-4500 and roll out till the slicks bite... Should I let it get into third for my burnouts?
NEW2MALIBU
920
idaho
That is exactly what my trans builder said. He also added if you have enough power just light it right up in 3rd gear.
injected
432
Quebec , Canada
ha ha ha :lol: Dont beleive everything you ear !! If you have a proprely prepared trany, it does not mater in what gear you are . transmission-wise, a stock transmision as a slow down band that is aplied in 1rst gear.But most of you guys have built transmission that had their band discared ,so does not mather.For stock transmission,first gear for sure.For all other,what ever you need for the right burnout !
