Can't get elcamino to hook up
1984 El Meano
New Member
Nov 20, 2018
I have been fighting this traction problem for a wile now. It's a 1984 el camino sbc 383 with a small 192 blower on it . And i have been spraying on it 180 shot , hughes th350 with a tight 3000 converter in to a GN 8.5 with 3.90 gears and hoosier slicks 29 10.50's15. front suspension is as follows qa1 upper drag race controll arms 6 cylinder springs ,qa1 single adj shocks, stock lower control arms with delumn bushings , low friction ball joints, no swaybar. Rear is umi dbl adj lower control arms, qa1 150lbs springs, baseline upper control /box kit , qa1 dbl adjust shocks and a hellwig sway bar part #55809 I NEED HELP
1984 El Meano
New Member
OK I have plotted out two different IC length and anti squat
1st A/S 176.09 2nd A/S 152.08
ICL 35.44 ICL 43.56
ICH 10.93 ICH 11.61
currently set at the 2nd now . what should it be at ?
Similar threads
