I installed a set moroso trick springs in the rear. It lowered the car and I loved the stance. Unfortunately the car bumps the tires on launch. I am using a set of comp eng. rear shocks. I was told if I use a set of Strange single adj. shocks in the rear it would cure the problem. True? I would like to lower the car in the rear. Drag only! As you can see in the sig I have room to come down on the 28x10.50
