Converting the Slow-wagon to t-56
I was considering that or a button on the shifter ball if I went with a T56.
4,770
39
Can the solenoid be removed altogether? Is it common to miss the 6th gear gate and engage reverse by mistake? Or can something else be put in its place with a spring that is stiffer than the 5-6 gate, but not overwhelming?
MISFITmalibu63
7,163
The Sticks... Tewksbury MA
ordered the clutch kit and new hydraulics, just have to convert to manual speedo setup and decide if i am going to relocate the shifter or notch my bench
4,770
39
Have you decided whether to replace the tailshaft housing with a modified one? or to use the device that converts VSS pulses to a motor that spins the speedo cable?
Killerdave8813 uses the converter in his car.
MISFITmalibu63
7,163
I'm going to convert the trans to a mechanical speedo, don't want to run extra wires, and converting isn't much more than the cost of the box.
Anyone relocate the shifter on a stock t-56?
This has taken a back seat until I finish putting the 2 door back together
