So the studs I have are a base size of 7/16-14. The size stated for a 7/16-14 tap is size U (.3680). I have a set of drills with a lot of missing pieces, but have a 23/64 (.3594), which is the size just below U (-.0086). I would've already had my answer but someone's borrowing my truck so I'm stuck here... the 23/64 is a loose fit in the stud opening, which makes me wonder do the heads actually need to be drilled before being tapped? I measured one of the original press-in studs and it came out to .3725 (+.0045).
