I have been looking for some backspacing info in the tech section on the main page. I couldn't find it. Searching just came up with thousands of posts with varying degrees of help. Rather than start another thread with the same question we see all the time on here I came up with this>
Idea: Everyone post up their wheel and tire combos in a sticky thread in the new "wheels/tires/brakes" section.
Leave only this info:
Front:
Wheel diameter, width, and backspacing
tire size
Rear:
tire size
Mods: A short description of any mods needed to fit those tires.
Edit: TonyD suggested pics. Lets see 'em!
Mine:
Front:
factory 15x7 rallys
235/60-15
Rear:
factory 15x7 rallys
235/60-15
Mods:
1/2" lowering springs all around...poly bushing...the tires look like donuts! :?
Autometer
1,239
Houston/Texas
www.addisonracing.com
Street Tires.
Front:
16x8 and 5.0" backspacing
245/50-16
Rear:
16x8 and 4.5" backspacing
245/50-16
No mods needed.
Drag Racing.
Front:
15x3.5 and 2.25" backspacing
165-15
Rear:
15x8 and 4.5 backspacing
26x10.5
No mods needed.
Front:
15x7 4" Backspacing
225/70/15
Rear:
15x8 4" Backspacing
275/60/15
Mods:
No Mods other than a non sagging suspension
us wheel chrome rallies...15X8 with 4.1" of back spacing.. Pep boys futura 245/50-15s...Front rub a little on the inner fender during a hard coner and hitting a bump..
Sagging front V 6 coils with a 4.3 in the car..Stock rear coils from a 95ish mustang..Pics in sig
81classic
2,833
North Port, Fl
Front:
15x7 4" BS
225/70/15
Rear:
15x8 4" BS
265/60/15
Needed 3/8" spacers to clear stock frame rail
dgumoe
121
Smyrna, Georgia
rears, 15X8 3.5 backspace, 28x10.5 tire. little bit of beat and bang on rear of frame rail to clear when the tire balloons at speed. fronts are 15X3.5. not sure on the backspace.
ILLEGAL REGAL
7,160
Tinley Park,IL
Front:
Wheel diameter- 15", width- 4"
tire size- 26" M/T ET Front
Rear:
Wheel diameter- 15", width- 9", and backspacing- 5 7/8"
tire size- 28/10.50 M/T ET Drag
Mods: Chevelle 12bolt that needed deeper backspace, frame notch just even with the factory wheel tubs and rolled fender lips.
Pics-
http://img.photobucket.com/albums/v228/ILLEGALREGAL/DSC02366.jpg
http://img.photobucket.com/albums/v228/ILLEGALREGAL/31150316507_0_ALB.jpg
http://img.photobucket.com/albums/v228/ILLEGALREGAL/99736163407_0_ALB.jpg
Frame notch- http://img.photobucket.com/albums/v228/ILLEGALREGAL/89988163407_0_ALB.jpg
Doug Keen
2,259
Central, Illinois
Front 15x4
Moroso DS2's 26-4.50-15
Rear
15x9 3-3/8 BS
28x10.50x15 ET DRAGS
Frame notch and rear end narrowed 1" per side
GreenDragginBu
6,293
N.E. Ohio
Front:
15x4" with 165r15
Rear:
15x8 with 4" B.S.
275/60/15 Drag Radial
Stock width rear
fender lip trimmed, but not needed (did because previous 12 bolt)
a lil under 1/2" clearence between tire and frame rail
DeltaT
1,050
Nor Cal
Front:
Wheel diameter- 17", width- 8", backspacing 5.25"
tire size- 245/40/17 BFG Killer Dry KD
Rear:
Wheel diameter- 17", width- 9.5", and backspacing- 4.5"
tire size- 275/40/17 BFG KD
Mods: Moser 12bolt (stock width), Wilwood discs, and trimmed inner fender lip.
Pix:
Jim
My Site: http://home.mindspring.com/~jim_fisk/id1.html
Hiway
3,932
Enola Arkansas
FR- 15 x 3.5 with 165/15 radials
RR- 15 x 8 5.5" bs with 275/60 radials or 28x9 slicks
fr has moroso's heaviest drag springs, cheap 90/10's, speedway a-arms
rr has cut stock springs, ssm lowers, iceman uppers, bags, lip rolled, frame
notched some at back of tire, all around a 69 chevelle 12bolt
18x8 front 4.5" BS 245/45/18
18X9.5 rear 5.5" BS 275/35/18
3" OPG Lowering springs
Brian
Duts87ss
176
Ocean Springs, MS
16x8 '99 T/A wheels with 245/50/16 tires front and rear. Had to use 2.25" adapters (2.5" adapter would have given a wider track).
Brian, did you have to use any type of adapter/spacer to make the 5.5" spacing work on your rear wheels?
No I didn't, but I have about a 1"1/4 between the tire and the frame. I need to beat on some parts of the wheel well though. Thanks
Brian
Front:
15x 8 Rallys 4" BS
255 60 15 BFG
Rear:
Same
coil blocks front and rear. And yes, they rub ALOT!!
78_Elky
1,680
Oregon
smlblk78.onlineshowoff.com
Front
15x8
215-65-15
Rear
15x8
235-60-15
no rubbing and no problems at all (they may be 15x7 rims not sure got them at a swap meet)
5-door
3,845
Cottage Grove, MN
www.jtraceshop.com
Front: 15"x3.5" Weld Prostars 15"x6.50" M/T
Rear: 15"x8" Weld Prostars with 3 3/8" backspace 28"x11.5" ET Streets
