Here are mine..
Fronts and rears tires are BFG G-Force with the American Racing TTII's
Fronts: 17X8 4.5 BS 245/45/17
Rears: 17X9.50 5.00 BS 275/40/17 (Fender Lips Are Rolled!)
Ohh baby! :p
-Jim
ties
5-door said:
Front: 15"x3.5" Weld Prostars 15"x6.50" M/T
Rear: 15"x8" Weld Prostars with 3 3/8" backspace 28"x11.5" ET Streets
hey 5-door........just mounted Hoosier 28x10.5 x15 meats under the car today!!! same size as the m/t et. street 28x12.5 tires... and got about 1 1/2 inch of clearance....!!!! YEAH!
weld draglites 15x8 rims with 3.5 backspacing!! rear wheels
Hoosier 28x10.5 meats
working on pic's.
Supe
15,116
Charlotte, NC
Front: 15x3.5 Draglites with 165/15's
Rear: 15x8 Draglites with M/T 28x10.5 stiff sidewall ET slick. 4.5 b/s, frame notched to seam/inner wheel housing, no spacers, 14"x150lbs springs in the rear.
Turbo1dr
2,232
New Bern NC
www.turbomalibu.com
Front: 15x7x3.5 Draglites with 215-65-15's
Rear: 15x10 Draglites with 5.5 b/s, frame notched. 275-60-15's. I'm getting rid of these and going with the same size rim listed below.
Drag Race Only Rear: 15x9x5.5 Draglites with M/T 28x10.5 ET slick. Frame notched with no spacers.
TRENCHER
Front: 20x8 KMC Tempests with 5"bs
Rear: 20x8 KMC Tempests with 5" bs
MODS!!: FRONT:REMOVED INNER FENDERS, CUT FENDERS, DROPPED SPINDLES, AIR RIDE, MODIFIED LOWER AND UPPER ARMS, MODIFIED FRONT RAILS
REAR: CUSTOM ROUND TUBE UPPER AND LOWER DOUBLE ADJUSTABLE ARMS, RELOCATED MOUNTS, FRAME NOTCH TO SEAM, C-NOTCH, AIR RIDE, MINITUBBED
TIRES ARE KUMHO 255/35ZR20
Canadian-T-Bone
1,147
Abbotsford,B.C.
94 Vette wheels 17x 8.5 front with 245/45/17
17x9.5 rear with 275/40/17
2" drop spindles & 5413 moogrear springs
Scoti
264
Dallas Tx
Project: "LowTouring"
Front: 18 x 8 w/5.25" BS
tire size: 245-40-18
Rear: 20 x 10 w/6.00" BS
tire size: 295-40-20
Mods: Notched frame rails w/mini-tubs; CurrieTrac rear arms; SC&C Comp 2 w/drop spindles
Front: 15 X 4 with 1.75 Backspace and 26 X 4.5 - 15 ET
Moroso's lightest spring with 2 inch drop spindles
Rear: 15 X 8.5 with 5 inch Backspace, frame notch and removed fender lip, 325/50 Drag Radial
28 X 10.5 Slick
275/60-15 Drag Radial
Signature pic is with a 275/60 MT Drag Radial
My site has other pictures and info
http://www.outlawradial.net
Check the my projects link.
