fellow soldier
I'm currently in Iraq as well. I'm running
FRONTS
195 70 14's
14X6 rim BS forgot
REARS
295 59 15's
15X10 rim 4 inch BS
Mods
SSM upper and lower lift bars, air shocks, 90/10 drags shocks up front
I have about 1 inch between tire and frame the other trick I use is jack the rear of the car up so the axle hangs then fill up air shocks with 100-120psi then let the car back down. I found this makes for a stiffer ride but gives the little extra so tires don't rub on a hard corner.
JASHELL1562
165
CLEVELAND , TN
WHEELS
BOYDS SMOOTHIE 2'S 17 X 7 W/205 40 17 ON THE FRONT , AND 17 X 8 W/235 40 17 ON THE REAR 4.5 BS ALL AROUND
Front 15 x 3 1/2 Cragar Dragstar Hoosier 26/4.0/15
Rear 15 x 15 Cragar Dragstar 7 1/2 backspace Hoosier 29.5/11.5W/15
RamAir468
196
Albany, New York
Fronts 15X4- 215/65R15
Rears 15x8- 275/60R15 BFG Drag Radials
Centerline Warrior wheels- Front & Rear
Nice
McssGmachine said:
18x8 front 4.5" BS 245/45/18
18X9.5 rear 5.5" BS 275/35/18
3" OPG Lowering springs
Brian
What wheels did you use?
I am looking at Corvette C6 wheels.
Let me know!
5-door
3,845
Cottage Grove, MN
www.jtraceshop.com
Rear: 28x12.5 ET Streets on 15x8 Weld Prostars with 3 3/8" backspacing. No frame notch, wheel lip is trimmed.
Front: 26x6.50 MT Sportsmans on 15x3.5 Weld Prostars.
Killermalibu
5,789
Litchfield NH
www.instagram.com
Centerline Meteor Wheels
17x7 front with 3.5" backspacing
235/45/ZR/17
same wheel in rear but different size
17x8 rear with 3.5" backspacing
255/40/ZR/17
Front
16x8 5 spoke S10 ZQ8 wheels
245/50/18 Falken Ziex412 tires-25.5" dia.
Rear
255/50/16 Falken Ziex412 tires 26" dia.
Mods
Edelbrock/Eibach lowering springs on an "83" Wagon
