Turbo1dr
2,232
New Bern NC
www.turbomalibu.com
Well, since this thread was brought back up here's a picture of what I'm running now. These are 28x10.5 MT slicks mounted on 15x9's with 5.5 back space. Frame is notched and fender lip is gone.
Front:
15x8
205/60R15
Rear:
15x10
4" backspace
4.75" total backspace with tire
295/50R15
v8liveson
Wheels/tires
I just put on a new setup.
Rear: 275/60/15 BFG T/As on 15x8 wheels with 3" backspacing. Probably could fit 3.5" backspacing. Frame rails are welded and also have air shocks to hold up the rear end. Stock fenders. Looks pretty good- wide, but does not stick out.
Front: 245/60/15 BFG T/As on 15x7 wheels with 4" backspacing. Fronts rub when turning; I need to order spacers sometime. Ideally, I would move these out about an inch on each side to give it a wider stance.
Wheels/tires
Mt et drag wheels: 15x8 rear w/ 4.5bs & 15x4 fronts
Mt 295-65-15 drag radials rear w/ 26x7.5 sportsman fronts 8)
15x7 up front, 225 65 15's, 15x8 in the rear, 255 60 15's
FRONTS: 15X4 Weld prostars,2 1/4bs W/ Mickey Thompson 15X6 Sportsman Radials
REARS: 15X8 M/T ET DRAG WHELS 4.5 bs , 295/65/15 ET drag radials
Max frame notch, Mini tub. No lip. I need to lower the car 1-2 " and I'll be all set
U.S. Wheel -84 Series Black Daytona
16"x7"
225/50/16
4" BS
Same wheels and tires on front and back.
Stock suspension.
ReRod
86
New Ulm, MN
Fronts: 15x6 Wheel Vintiques chrome rally wheels (3.5" BS); 215/60R15's
Rears: 15x8 Wheel Vintiques chrome rally wheels (4" BS); 255/60R15's
makurtz
Front: Bogart Force Five 15x4 with 1.75" b.s. Moroso DS-2 26x4.5 tires.
Rear: Bogat Force Five 15x11.5 with 6" b.s. Beadlock rims, M/T 29.5X10.5S drag slicks.
Rear frame rails notched to inside wall, mini-tubbed, fender lips rolled.
[/img]
[/img]
