Doug Keen
2,259
Central, Illinois
Front 15x4
Moroso DS2's 26-4.50-15
Rear
15x9 3-3/8 BS
28x10.50x15 ET DRAGS
Frame notch and rear end narrowed 1" per side
GreenDragginBu
6,293
N.E. Ohio
Front:
15x4" with 165r15
Rear:
15x8 with 4" B.S.
275/60/15 Drag Radial
Stock width rear
fender lip trimmed, but not needed (did because previous 12 bolt)
a lil under 1/2" clearence between tire and frame rail
DeltaT
1,050
Nor Cal
Front:
Wheel diameter- 17", width- 8", backspacing 5.25"
tire size- 245/40/17 BFG Killer Dry KD
Rear:
Wheel diameter- 17", width- 9.5", and backspacing- 4.5"
tire size- 275/40/17 BFG KD
Mods: Moser 12bolt (stock width), Wilwood discs, and trimmed inner fender lip.
Pix:
Jim
My Site: http://home.mindspring.com/~jim_fisk/id1.html
Hiway
3,932
Enola Arkansas
FR- 15 x 3.5 with 165/15 radials
RR- 15 x 8 5.5" bs with 275/60 radials or 28x9 slicks
fr has moroso's heaviest drag springs, cheap 90/10's, speedway a-arms
rr has cut stock springs, ssm lowers, iceman uppers, bags, lip rolled, frame
notched some at back of tire, all around a 69 chevelle 12bolt
18x8 front 4.5" BS 245/45/18
18X9.5 rear 5.5" BS 275/35/18
3" OPG Lowering springs
Brian
Duts87ss
176
Ocean Springs, MS
16x8 '99 T/A wheels with 245/50/16 tires front and rear. Had to use 2.25" adapters (2.5" adapter would have given a wider track).
Brian, did you have to use any type of adapter/spacer to make the 5.5" spacing work on your rear wheels?
No I didn't, but I have about a 1"1/4 between the tire and the frame. I need to beat on some parts of the wheel well though. Thanks
Brian
Front:
15x 8 Rallys 4" BS
255 60 15 BFG
Rear:
Same
coil blocks front and rear. And yes, they rub ALOT!!
78_Elky
1,680
Oregon
smlblk78.onlineshowoff.com
Front
15x8
215-65-15
Rear
15x8
235-60-15
no rubbing and no problems at all (they may be 15x7 rims not sure got them at a swap meet)
5-door
3,845
Cottage Grove, MN
www.jtraceshop.com
Front: 15"x3.5" Weld Prostars 15"x6.50" M/T
Rear: 15"x8" Weld Prostars with 3 3/8" backspace 28"x11.5" ET Streets
