Floor pan support brace assistance
mechanicmangg
Member
Dec 14, 2009
6
Been restoring my 81 Malibu full body off frame. My rear floor support brace (In front of the rear wheel opening) on the underside is rusted on both ends.
This is where the frame/bushings set and the frame/body bolts run through.
Been trying to find a replacement support brace, but can only locate it for A-bodys. ](*,)
Does anyone know where to locate this item?
Any and all help would be greatly appreciated.
mechanicmangg
Member
Dec 14, 2009
6
Not trying to shell out the money for another vehicle as a donor, then separate the body off the frame to even get a good look at the braces to make sure they are not in the same condition before buying the shell.....:?
I am thinking about getting a floor pan support brace for an A-body, and stitch weld in the 2 ends that need to be replaced.
(Cant believe that they do not make replacements for the G-Body)
Has anyone done this? Is so did you have any issues getting it to fit properly?
StreetBu
4,162
Upstate NY
Not made unfortunately.... :(
U floor pan Autobody/Paint Technical 4
G floor pan question Autobody/Paint Technical 3
B FLOOR PAN HELP Autobody/Paint Technical 2
M Any 1 in st louis that can remove and install new floor pan Autobody/Paint Technical 2
H stock floor shifter cable? Transmission Technical 0
V Turbo350 column to floor shifter conversion? Transmission Technical 2
U Floor pans? Autobody/Paint Technical 1
R 79 Elco soft pedal to the floor. Wheels/Tires/Brakes Technical 2
M Floor to firewall seam question Drivetrain Technical 3
83LSWagon Latex paint on interior floor? Interior Tech 2
fastrat350 ebay floor patch pans? Autobody/Paint Technical 6
P Automatic floor shifter (neutral safety and reverse light ) Electrical/Wiring Technical 4
D Tilt floor shift steering column... upper portion 'wiggles' Interior Tech 12
C brakes to the floor Wheels/Tires/Brakes Technical 5
widomkr79 brake pedal goes to the floor Wheels/Tires/Brakes Technical 9
R Wagon cargo floor removal. Interior Tech 1
44-bu Rotten rear floor Autobody/Paint Technical 8
D Rear floor patch panel search Autobody/Paint Technical 1
7 Is anyone running a floor shifted automatic with bench seat? Interior Tech 9
3 Floor shifter for automatic Transmission Technical 3
jakedog Backup Lights, Where to hook up with Floor shifter ? Electrical/Wiring Technical 6
STROKERBU G BODY DONOR FLOOR PANS? Autobody/Paint Technical 0
STROKERBU FLOOR PANS Autobody/Paint Technical 1
79ChevyBu Floor braces Autobody/Paint Technical 3
79ChevyBu floor pans Autobody/Paint Technical 5
StreetBu Knock knock knocking on my floor Drivetrain Technical 7
S Switching from Colum to Floor Shifter Drivetrain Technical 6
80Grand_LeMans Looking to seal up trunk floor. Autobody/Paint Technical 2
79izfine frame off / floor repair Autobody/Paint Technical 1
GreenDragginBu Floor pans install pics anyone?? Autobody/Paint Technical 8
A no backup lights after floor shifter installed Electrical/Wiring Technical 2
7 Dorman engine pan gasket Drivetrain Technical 0
7 What's the best oil pan for a 73 350 ci ? Drivetrain Technical 11
Time Warp Which BBC gen IV oil pan Drivetrain Technical 12
D Ls swap mounts, oil pan combo LSx Tech 4
D Notch for LS1 pan LSx Tech 6
R Will a ZZ502 oil pan fit in a gbody Drivetrain Technical 3
D G BODY OIL PAN REMOVAL ???'S Drivetrain Technical 6
F Need Advice on Extra Capacity Oil Pan Drivetrain Technical 1
7 stroker oil pan problem Drivetrain Technical 9
S Small Block Chevorlet Oil Pan Drivetrain Technical 2
H trans pan for 200r4 Transmission Technical 2
C help with cts-v oil pan and drag link clearance LSx Tech 4
Ed Cannon BBC Hambergers oil pan hitting steering. Drivetrain Technical 2
Ed Cannon BBC oil pan question. (Hambergers) Drivetrain Technical 5
Ed Cannon Which oil pan are bbc guys using? Drivetrain Technical 10
S F body oil pan with 1" setback mounts in G body? LSx Tech 6
LIVE4RDO BBC 454 GENERATION VI!!! OIL PAN Drivetrain Technical 4
B help with oil pan choice LSx Tech 9
U fbody oil pan for a gbody LSx Tech 14
Similar threads
