ford 9inch rear end question
DixonK
135
Sweden, Gothenburg
1x 9"type 57 Ford,1560mm,3,10,4 1/2
1x 9" 1520mm,4 1/2 bolt,
1x 9" 1700mm,3,50,5 1/2
1x 8" 1460mm,2,79,4 1/2
there's a guy Selling some rearends Close to where I live here in sweden, can I use any of these for my Malibu -79?
I don't know what to look for but I want to swap out my stock rear end, I Think its a 7.5 10bolt 2.10~ gears
thanks in advance
gman415
883
Chattanooga
I'm not sure I'm following you numbers, a stock rear for a G-body is 52" backing plate to backing plate. That's 1330+/- mm. With 2 1/2" (not sure on this , just a guess) of brakes on each side that's 57" (1450mm+/-)
With that said, you'll still have to have all the brackets welded on. I don't know your fabrication skills, but if you have to pay for this plus buying the rear, you could buy a housing made for your car. Keeping in mind you will also have to buy a center section, and those can get pricy.
TURNA
6,028
Socialist NY
The 57 is a War case. It was used from 1957 to 1964, and has the extra rib on it.
I am not a fan of them, but some people like them.
If the others have an N on the center section That is a good start.
The WAR case may have an N on it but it is not Nodular
TURNA
6,028
Socialist NY
DixonK
135
Sweden, Gothenburg
These are really cheap its on sale otherwise he's tossing them to make room, Would any of these fit if I give them to a shop to weld off the brackets from the stock? Or do you buy new brackets to weld on?
My malibu is a really long term project since I'm new to this car buisness thats the reason why I dont want to fix up my stock rear! I heard these are good rear ends! Just want to buy one that doesnt require much work to fit / except welding and money :)
TURNA
6,028
Socialist NY
They all seem a bit to wide for a G-body Unless you get a special offset wheel.
But you wont know until you messure it yourself and see where things line up
