ford 9inch rear end question
DixonK
135
Sweden, Gothenburg
1x 9"type 57 Ford,1560mm,3,10,4 1/2
1x 9" 1520mm,4 1/2 bolt,
1x 9" 1700mm,3,50,5 1/2
1x 8" 1460mm,2,79,4 1/2
there's a guy Selling some rearends Close to where I live here in sweden, can I use any of these for my Malibu -79?
I don't know what to look for but I want to swap out my stock rear end, I Think its a 7.5 10bolt 2.10~ gears
thanks in advance
gman415
883
Chattanooga
I'm not sure I'm following you numbers, a stock rear for a G-body is 52" backing plate to backing plate. That's 1330+/- mm. With 2 1/2" (not sure on this , just a guess) of brakes on each side that's 57" (1450mm+/-)
With that said, you'll still have to have all the brackets welded on. I don't know your fabrication skills, but if you have to pay for this plus buying the rear, you could buy a housing made for your car. Keeping in mind you will also have to buy a center section, and those can get pricy.
TURNA
6,028
Socialist NY
The 57 is a War case. It was used from 1957 to 1964, and has the extra rib on it.
I am not a fan of them, but some people like them.
If the others have an N on the center section That is a good start.
The WAR case may have an N on it but it is not Nodular
DixonK
135
Sweden, Gothenburg
These are really cheap its on sale otherwise he's tossing them to make room, Would any of these fit if I give them to a shop to weld off the brackets from the stock? Or do you buy new brackets to weld on?
My malibu is a really long term project since I'm new to this car buisness thats the reason why I dont want to fix up my stock rear! I heard these are good rear ends! Just want to buy one that doesnt require much work to fit / except welding and money :)
TURNA
6,028
Socialist NY
They all seem a bit to wide for a G-body Unless you get a special offset wheel.
But you wont know until you messure it yourself and see where things line up
