g force crossmember
art
249
Mastic, New York 11950
I found by assisting the crossmember up with the floor jack, I was able to "adjust" the floor enough to get my crossmember in after I notched it. A 5 lb hammer gently helped it along as well. Just little taps.
grizwald
3,300
Ontario, Canada
bringing this back from the archives....i FINALLY got around to trying to fit this in the car this weekend. i took out the heat sheild that was on the passenger side floor and used a floor jack to push the x member up the extra 1/8" it needed to get up on the frame. fit no problem!! after wards, i didn't even need a hammer to move it forward or backward, i could do it by hand (side to side was a different story). i must say that this upgrade is worth the $$$. i bolted a set of race bullets right to the headers and there are no clearance issues at all!!
sorry...i'm just pumped that it fit!
my g-force member was in the body as well untill I replaced the body bushings..now I got about a half inch from the top of the exhaust cut-outs to the floor with the transmission's wieght on the member. They are much better than the factory member notched. Ties the frame together well and stiffens up the chassis a little bit. All around good investment.
racecar77
2,438
Crete,IL
I've had discussions with guys about this before. They say that my G-Force crossmember is too heavy. It is heavy, but my argument is that it doesn't just hold the transmission up. I think that it becomes a structural member and for sure ties the frame together. So what do you guys think? No disrespect to Iceman or other fabricators but I just think the G-Force is stronger. I'd love to get that weight out of my car, so someone please convince me that I'm wrong. Lee
I said this somewhere else as well. ICEMAN used to make crossmembers nearly identical to the the g-force ones before Summit took them over. He was basically forced to stop from what I understand. I wonder if he would make one on request.... I would much rather have given him my money than Summit when I ordered mine but I was home on R&R from Iraq and time was of the essence. ICEMAN makes great stuff and is a sponsor of the site (see above 8) ). I still want to try his light weight member just because I know he makes awesome stuff.
I think the beefy crossmember stiffens the chassis up a bit. No way to actually prove that. I can't imagine bolting a hefty chuck of iron like that in between the frame rails doing anything else though... :lol:
