LS6 Tommy said:
Damon said:
A correct factory vented cap is what you want- it will not leak. It allows air INTO the tank quite readily (relieving any vacuum condition inside the tank instantly). It will only allow air OUT of the tank when pressure inside the tank reaches about 1 PSI (to prevent rupturing or distroting the sheet metal tank on hot days).
That's exactly how the "old" caps work, but unfortunately there is no such thing for a G-body or any other emissions era car...
I agree. I've kept my eyes open for one for quite awhile with no luck.
I just stuck a small piece of 3/8" fuel line on the end of the vent tube right above the rear axle and put a plastic cheapie fuel filter on it to filter any dirt or bugs that may try to get in the tube. I don't drive the car in the rain or on real dusty roads so I am fine with it.
The only downside I see to my setup is- If the car were to roll over and land on it's roof, I
think gas would just run out of it. I've never had the car upside down so I don't know for sure.
