Got my big brake parts... some questions
355_79bu
1,240
Cotter, AR
My rotors were around $60.00 each. Calipers were around $25.00 each. Both purchased from my local parts store.
355_79bu
1,240
Cotter, AR
Fast Lane Racing said:
did the 1990 caprice come with differant size rotors? or can i just go to a junk yard and get the spindles without worring about it?
I believe they still came with 11" and 12" rotors in 1990. Just take a tape measure along to be sure. Most wagons had 12" rotors and the big bearing spindles FYI.
1QwikBu
1,387
olympia washington
speedwaymotors.com has them in CM for 54.00 each if your worried about strength
Is there anything else from a caprice that you can use on or for a malibu?
If i'm not mistaken i think a buddy of mine, his mom has one that they are going to get rid of, maybe this could work to my advantage :D
I can't get a part number to show up for the Left side, All i can get is the
14-0809-5R
is the left side the same a-arm but with the ball joint up the other way?
14-0809-5R
it doesn't show in the catalogue, just call and ask, thats what i had to do... and in answer, yes it's basically the same arm with the flat part for the ball joint flipped over
I have posted this parts list a bunch of times. Maybe we can get a "sticky" so I don't have to keep wearing out the "search" ?
Here's the B-body/1LE swap info:
The 1LE rotors are 12". Any year IROC Camaro or the same years of WS6 Trans AM should get you the right rotors. For upper A-arms and springs I used Global West's stuff.
Here's the parts list I used:
Spindles and calipers are from 12" brake 78-90 full size Caprice, Caddy, Delta 88, and Pontiac. Typically wagon, police or with HD towing package.
Brake calipers, (1)#18-4021, (1)#18-4020
Brake flex hoses, #BH36848
Brake caliper hose bolts, #483-205
Brake pads, # D52 ( I used Performance Friction pads)
Brake rotors, 1LE, #5994
Wheel bearings, 1LE inner, #BR6
Wheel bearings, 1LE outer, #BR3
Bearing seals, 1LE, #19753
Hub grease caps, 1LE, #13977
If you're tearing down the steering too, here's the part #s:
Tie rod, inner, 78 Malibu, #ES2034L
Tie rod, outer, 78 Malibu, #ES2033R
Centerlink, 78 Malibu, #DS909
Idler arm, 78 Malibu, #FA1013
Ball joint, lower, 78 Malibu, #FA3000
The tubular upper A-arms required should have ball joints already installed.
Nevermind. I just saw the list in the Suspension FAQ's forum. :oops:
this might sound stupid,
but are those GM part numbers, or numbers from a local autoparts store?
