Hazards, but no blinkers
78maliburat
616
cleburne texas
lights
take it to the speed shop ask for VERN just kidding first check for grounds going from harness to core support then pull out bulbs take test light see if you have power if not start at fuse box some older chevys had flashers that werent in fuse blk just hung down from dash? when blinkers are working you should feel flasher and fell it pulse also did you replacethe plate in colum somtimes they crack and dont make contact
HarrisonTX
3,332
Burleson TX
I have replaced the contacts, the cam, the wiring harness in the column, all bulbs are good, new flashers and fuses. this is the worst. I may rewire it all, it has to be a short somwhere. Jegs sells a kit thats $120 that will basically be me starting from scratch.
