Hedman headers fit with my old transdapt mounts!
Roller406Bu
396
Elizabethtown Ky
I recently put on some Hedman headers 1 7/8 ceramic coated from jegs.com
part number is 502-45036....
might help some one so there it is....Didn't have to hit or bend anything, unlike the pace setters I use to run....
BIG. T
19
I assume you are using the non setback plates?
There is someone on ls1tech using the non setback plates in a monte with the same headers I believe.
79loserbluebu
302
Illinois-60491
These are the same headers BRP sells http://www.brphotrods.com/mm5/merchant.mvc?Screen=PROD&Store_Code=BRP&Product_Code=MR45036&Category_Code=CNV7
Roller406Bu
396
Elizabethtown Ky
http://www.jegs.com/i/Trans+Dapt/969/4592/10002/-1
cutlass-388
151
Coventry, CT
I was wondering if these plates put the engine in the same spot as mounts on a Gen 1 engine? Reason being I want to keep my G-foce crossmember and 2004R transmission where they are so I don't have to do anything with my good driveshaft. Trying to plan all this stuff out ahead of time to gather parts that work and not piss away $$ unnecessarily. Know what I mean? Thanx Steve
uneek1976
56
Any pics?
Roller406Bu
396
Elizabethtown Ky
Any pics?
Check the vid section i posted a vid bout a month ago...u can see them on there...
82dragonwagon
35
Are those for the 98-02 f body?
Roller406Bu
396
Elizabethtown Ky
There for a g body^
