Help Building Big Block
Malibu Monte
I am building my first ever big block this winter and need some help. I have always been a small block guy and don't know a lot about big blocks. This is not for a malibu, but for a '69 Nova I am building. I want it to be a streetable car that can run high 11's easy on E85. I have an '88 four bolt main "high perf pass" block that will need to go .30 over.
I need help picking a rotating assy. I want it to be of good quality and made in USA, but I don't want to spend an arm and a leg.
I found this on ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300450941078&ssPageName=STRK:MEWAX:IT
I am going to call them tomorrow to ask some q's but, does anyone know if that is a good kit? Or should I go eagle or scat.
I heard that eagle and scat cranks are made in China now, is that true?
Next on to heads what can I do that is affordable that will make my power goals? Would a set of old oval ports with some bigger valves and port work done do it?
Like I said I am new to big blocks. let me know if I am out of line on my et estimate or if it is do able?
toxicbu
616
romeoville il
years back i had a 40 over 454 stock
truck short block , i installed a 622 roller
and edelbrock big port 6055 heads
on 87 octane it ran an 11.80.
then the rings gave out .
that was a bad year.
MalibuRacing
3,465
www.maliburacing.com
Do you know which heads your are going to use? Like Robert said, your CR may be a little low depending on chamber size. High 11's should be a breeze with a 454. I ran that with a stock cast crank, stock rods (bolt upgrade) and hydraulic flat tappet cam.
Malibu Monte
I called the company today and yes the crank is imported as well as the rods. They also claimed that eagle and scat are also. I plan on taking the motor, stock cast crank, rods, and heads to the machine shop tomorrow and will hopefully find out on the condition and buildibilty of them early next week.
That sound like a build I would be more happy with Phillip. I could buy forged high compression domes, arp rod bolts, a flat tappet cam, roller rockers, and probably balance the crank and rods too.
As far as the heads I am not sure. I will try to run the casting numbers tonight. I think they are mid 70's truck oval ports. So probably not the best. I am going to check with my machinist to see if he has any that are better or knows of any. The good thing is if I don't buy a rotating assy I can afford better heads.
Robert1320
Eagle, Scat, Cat, PEP, and several other are all import from over seas, Ohio Crank as well.
American parts very well may bust you budget. If you can afford them I always recommend supporting American Made.
The large Oval port would be fine stay away from the little peanut ports.
10.5-1 is a good E-85 compression ration. And you can still add boost to it at 10.5-1.
Malibu Monte
Called my machinist today on his cell, His wife is sick and he will not be back in until monday. So If I can get the motor up there then I would know if it is all good later next week. I also ran the casting numbers on the heads tonight. They are 70-73 Lt. Truck 400/402 heads. Larger oval ports. Would these be good builders since they are from the early 70's?
Some info on the car and the rest of the drivetrain. It should weigh around 3400 pounds. The motor will be backed by a 400 turbo "switch pitch", 3.73 gears, and proably a 255/60 drag radial. So what do you all think? Is this a good combo for my goals?
Thanks for everyone's help so far.
abigda
616
Springfield, MA
I'm running 80's oval ports that my machinest fully worked over, and 11-1 compression. Makes awesome torque. Aluminum heads would have been nice, but $900-$1,100 a head is pricey
Robert1320
Something to think about on your rebuild. Since your looking at buying Crank, Rods, Pistons.
Throw a little stroke in it and take to 0.060" over with a good block and make it a 496cid.
That with the smaller heads will make a VERY torquey motor. Then you could go to an even
lower numerical gear.
Malibu Monte
Robert,
If I do buy a roating assy I will buy a 496 kit, but I am dissapointed because all of the "affordable" kits are from overseas. I have never built a motor with any parts that weren't American and I don't know if I can compromise my moral standards like that and I know I probably can't afford a kit that would be completely American. For example I google searched American 496 assy and came up with this http://www.competitionproducts.com/HRC-Track-Smart-Race-Assembly-Chev-BB-496-Dome/productinfo/RATB496D/. $2600 for what is supposedly America made parts, also found a Howard's cam kit on Summit for 2900 that is American. I just don't think I can spend that much. So if my machinist thinks my crank and rods are usable I will probably reuse them for now. I do appreciate your information and agree a 496 would be a great setup for this car.
