No, bore centers are the same, You can put a 305 crank in a 350 block and end with, well, 350 ci.
StreetBu said:No, bore centers are the same, You can put a 305 crank in a 350 block and end with, well, 350 ci.
Doober said:Eh, you'd spend about the same at a junkyard on a 305 or 350, so why not go for a bigger displacement?400s are a little different than a 305/350.
CanonFodder said:Doober said:Eh, you'd spend about the same at a junkyard on a 305 or 350, so why not go for a bigger displacement?400s are a little different than a 305/350.
In displacment and casting numbers, just like the 350 and 305 comparison? :roll:
Maybe a couple steam holes to scare away some people. The argument of displacement is infinite. Why not just put a Merlin 16 cylinder airplane engine in the thing? ](*,)
My point is to use what you have. And this guy has a 305. Advice to nix what you have and buy different because of 45 ci seems beyond ludacris.
So to answer the original guys post constructively, answer the TPI question with something about wiring, fuel injection, or the overdrive transmission. The old retort of "gitta tree fitty" helps no one.
