HELP!!!!!!!!
malibumarine1979
25
Dillon SC
Hey guys got a huge problem with my motor mounts. The motor sets cocked to the left I replaced the motor mounts and that has not helped i done this before i put the new motor in but i did not mark the old ones. I am actually thinking of putting solid motor mounts. Im kind of stumped. Oh I checked the adjustments and they are maxed out as well.
bowtie81
5,008
sarnia, ontario canada
This happened to me aswell, I had truck mounts from my motor and went to use them. I could get one side on but the other was just a little out, so i used a set of car mounts and it dropped right in.
Redline396
265
clifton, nj
i used a set of solids for a f body.........worked out well for my big block swap............if your not sure of the holes to use in the frame,you can bolt them to the motor and lower it in and mark the holes.....then lift the motor and install the frame mounts......at least you will know where they go....good luck and let us know how you make out ken
Supe
15,116
Charlotte, NC
Bowtie 81 got it. The truck mounts will c*ck it to one side.
