ladder bar
Did you replace the rear suspension arms with ladder bars, or just add them? Bolt-in ladder bars are usually add-ons for leaf springs, or get used instead of upper & lower 4 link arms. If the front mount doesn't have the same pivot point as the front of the lower arms, it'll lock up the whole rear suspension.
Can you post up some pics or email me some pics , i want to do this in the future .
Thanks
greenone60 said:
no this is a art morrsion kit weld in i removed the upper and lowers control arms.and with back with coil over shocks.the kit had a panhard bar
OK Gotcha. I wasn't sure.
greenone60
22
huntsville alabama
got the ladder bars installed and done some testing,the 60 ft times stayed about the same with the bars iam now pulling the left front wheel off the ground would not do that with stock setup.running drag radials 275/60/15 bfgoodrich mild sbc best to date 7.04 1/8 mile.
will post some pics
