lowered a bit much.... now what?
Canadian-T-Bone
1,147
Abbotsford,B.C.
When i still had my malibu , under big bumps it would rub . I cut the plastic inner fender at the top & then install a flap of rubber over top of it . That solved the problem.
garyg
331
You need to make some major mods to the inner fenders. I've got two inch spindles and eibach 1.5 springs and I'm good lock to lock and a tiny bit of rub only in reverse. Don't ask me why I have no idea why its only in reverse. Take out the three bolts in the lip of the inner fender it might be four bolts. Now remove the metal inner liner that's between the lip and the plastic inner fender. Now cut and remove the inner fender all the way to mounting bolts on the body. Its a really bad explanation but with a little fiddling it can be done. I'll try to post some pics
melloelky
3,654
31
mass
i believe that when you drove in reverse,it transfered the weight to the front end and made the body and the tire relation a little bit closer then before
malibu hyde
My front tires rub /bottom out on bumps as well...Im running 2" drop spindles, 205/60r16 tires/rims n 350 engine with stock V6 springs though. Im sick of it rubbing/bottoming out...Thinkin on installing Moog 5662 front springs !! Any other ideas/opinions ???
motorhead
110
Ottawa, Ontario Canada
Lower the rear of the car or transfer weight behind the rear axle centerline. This changes the F/R weight balance of the car and take some load of the front springs. Or you are into spring pocket spacers to regain some height.
