Thanks Chevy! Yeah, they are alittle pricey for sure! Did you put both the front and rear in or just the rears? My rear is pretty good right now but will prob. change once I get the front squared away.
If you could, along with a few pics, measure your frame to ground height right behind the front/rear wheel (at the back of the large hole in the frame) I'd greatly appreciate it. My front is at 5-3/4" now (slammed ](*,) ) My rear is at 14". Also, how much room between the frame and the front lower control arm bump stop do you have if your running one? As mine sits now, I have 0" ](*,)
I actually ordered the fronts from Detroit Speed (back ordered at the time) and then cancelled until I get this height thing figured out. I'd hate to have to install, then cut or be back to where I am now.
I found a page in the 78-81 G Body manual that shows how to measure the factory ride height for the F40 & F41 suspensions. It's in metric so once I get it converted I'll post it on here. They'll be just numbers to start from.
It's allot to ask I know. Whenever ya get time,
Steve
Steve
