Ls1 t56 Clutch Bleeding
80bu
1,044
Oak grove,mo
How do you bleed a ls1 t56 clutch? I assume its like brakes. Also do they make a special tool to get on the bleeder or can I use a socket?
dynodanmanda79
60
Crestview, FL.
I found this method to be the most effective way to bleed the hydraulics:
http://www.ls1.com/forums/showthread.php?t=124254
It's a HELL of a lot easier than crawling under there to bleed the slave cylinder imo
kevind
868
Whitley City KY
I've had the trans out of My 06 GTO 3 times in the last month. I couldn't get mine to bleed like You would with brakes. I had someone hold the pedal down while I broke the bleeder in the bellhousing loose. I left it open about 5-10 seconds then tightened it back up. Mine normaly bleeds in about 5 times. Make sure that You keep fluid in there they don't hold much.
BAD78BU
63
Texas
what mount for the master cylinder for the clutch did you use? Also did you have to split the tunnel to make it fit the t56 I mean??
1320chevy
Member
Jun 25, 2011
8
34219 FL
the t56 is self bleeding, i just gave my kid $5 to sit there and pump it for half an hour. lol
