80bu said:
I am having issues with my t56 grinding going into 3rd gear, would it be easier to seperate the trans from the bellhousing to pull it that way or just pull the bellhousing and trans together?
Yes, I find it easier to leave the bellhousing attached to the engine and remove just the transmission. No reason to mess with the clutch and bellhousing if they're working fine. The t56 to bellhousing bolts are not inside the bellhousing. The front cover bolts are on the front, but im sure if your removing the front cover you want the transmision removed.
