This has been discussed a few times but can't find any answers to my problem. Will try and explain set up best I can. The car has most everything wired to a junctin box on the firewall. This is how I have the alt. wired. the post wire(red) is running to the battery(trunk) along w/a wire(red) that is coming from the stock wiring harness. The plug red wire is plugged into the juction box on firewall and the brown wire which has a diode runs to the factory harness. I am running a MSD 6al also wired to junction box. This is what I have tried at one time or another and it still runs when switch is turned off. Checked to make sure diode was wired right, ran all reds(post,plug,harness) to cut off, looped plug red to alt post. I know this is a lot of info to get through but any ideas would be helpful. It has to be something simple but ust can't put my finger on it. Only thing I haven't done was converted over to a one wire set up. The car is used only for drag racing and as you know won't pass tech this way. It's only a few wires how hard can it be?
