racecar77 said:
Thanks 355_79Bu. I'm going to rewire the cutoff switch the proper way. I didn't consider that the alternator would keep the car running and didn't have a rule book handy when I wired the car. I understand the reasons for the cutoff switch. I just thought it would work correctly the way I did it. I now know different. I'll just have to fab some new battery cables and run the alt. wire to the back. Thanks for your help, I appreciate it, Lee
You only have to make one short cable to connect the battery + to the switch, and connect the ground to the battery, add the alternator wire to the batt + side and you are done.
There is some sort of cable from the rear to the front already, correct? It would connect to the switch.
8 ga. on the alternator wire.
I have a stud welded to the frame at the rear for the batt - cable, and two studs at the frame in front for the engine block ground cable, and one for all the other grounds.
